Links with extra "\\\"
madnauseam
Post by madnauseam »
I was creating a custom template and I ended up with a lot of links that end with multiple "\\\\" chars.
I believe the correct link is still parsed, but this generates a lot of needless links.
Do you have any idea what could be causing this issue?
EDIT: I should have added a bit more info.
Take this link (NSWF)
Code: Select all
https://forum.candidgirls.io/t/fit-latina-in-onepiece-flex-gif/499923
In the Excluded links I have:
Code: Select all
^https?://(www\.)?candidgirls\.io
https://forum.candidgirls.io/privacy
https://forum.candidgirls.io/login
https://forum.candidgirls.io/tos
https://forum.candidgirls.io/guidelines
https://forum.candidgirls.io/categories
https://forum.candidgirls.io/u
https://forum.candidgirls.io/tag
https://forum.candidgirls.io/letter_avatar_proxy
images/emoji/
In the Included links I have:
Code: Select all
https://forum.candidgirls.io/uploads/    (this one is where the attachments are)
I have played a bit with the excluded pages parts in order to parse out needless code other than the image links, but I am still getting these extra links.
Once again, thank you.
Re: Links with extra "\\\"
It looks like all the links with the extra "\" characters are located before the "</header>" tag, so adding one [ Excluded Page Part ] like this should do the job:
Code: Select all
To: </header>
Another note. Why do you exclude www.candidgirls.io? There are no links to that website from the forum. I think the only Excluded URL (if you want to go that way) that you need is
Code: Select all
candidgirls\.io
And the only [Included URL] that you need is
Code: Select all
/original/
I think you are overcomplicating things.
madnauseam
Maksym wrote: 29 Nov 2024, 11:24 It looks like all the links with the extra "\" characters are located before the "</header>" tag, so adding one [ Excluded Page Part ] like this should do the job:
Code: Select all
To: </header>
Code: Select all
candidgirls\.io
Code: Select all
/original/
Thanks for your input, Maksym!
The idea I had in mind was to crawl a category, for example:
and download each thread from that category.
Perhaps I'm not going in the right direction and there is an easier way to do that?
You never mentioned you wanted the categories :( How did you plan to handle the pagination of the category pages?
madnauseam
So far I was allowing links in the form of " ...\t\ " and I was using the "Excluded page parts" to remove the links for other threads other than &page=.
But yeah, I am a noob with this, so I'm sure there are better ways to do this.
Yeah, that's the easiest way. Simply add
/t/
and
page=\d+
to the [ Included URLs ]
madnauseam
Thank you for all your help!
