Naming prefixes
Naming prefixes
Is there any way to make the first option from the expert tab under file naming act as a prefix on the original file name when in project properties? I've checked the additional naming options but that only has static options for prefixes and suffixes. This becomes an issue for me when pictures in a series are only named by number under the same post and If I just let the program renumber it off of that expert setting everything gets numbered wrong number and some a sequel pages have the wrong name.
Re: Naming prefixes
Right now it's only static prefixes and suffixes. But the thing that you asked for is in the to-do list. In the next major update it will be possible to combine the available naming options in any desired order.
As of right now - maybe you should use the Regular Expressions for your file naming? If you give me the URL and tell me what kind of names do you want I can try to help.
