Endless Slideshow Screensaver 2 beta
Re: Endless Slideshow Screensaver 2 beta
Yes, that is correct.
OK, I think this is doable. I'll try to add it to the next beta version.
Thank you Maksym.
Version 2.0.0.30 is available. In this release:
- A possibility to have both [ Include ] and [ Exclude ] media filters for tags and file names was added
- Horizontal and vertical space between media files in a slideshow zone and between the slideshow zones are now separate values (before that there was one value for both horizontal and vertical space). This should allow to place text between the rows of slideshow zones or media files without having to create the same space between the columns:
Before that, if you wanted vertical space for your text you had to give up the horizontal space as shown in this video made with the previous version:
Text placement video
- Wallpaper downloader module was improved
- A bug with the average and dominant color background placement that appeared when there were more than 2 columns or rows of media files was fixed
Superb Maksym. Works perfectly.
You are welcome!
Hello Maksym,
This is the second time I get this Access Violation with the new version.
Access violation at address 00BBFB6E in module 'Endless2.scr' Read of address 00000008.
This one can come from a particular transition. Can you please check every transition in the list by simply selecting it and activating the preview. Will you make it to the end of the list?
Hello Maksym,
I made it to the end (249) transitions. I let each one preview about 3 to 4 times with not issue.
Hmm. Interesting. Thank you very much for the information!
At what moment did you have that error in the screensaver? Was the transition running?
