Endless Slideshow Screensaver 2 beta
Re: Endless Slideshow Screensaver 2 beta
If you want several transitions on one monitor - use slideshow zones:
But the number of slideshow zones is constant, it does not change while the slideshow is running.
JRB
Post by JRB »
Hello, what is new in beta 2.0.0.25 ?
Several bugs were fixed. No new features were added.
JRB
Re: Endless Slideshow Screensaver 2 beta New Issue
Post by JRB »
Hello Maksym, there seems to be an issue with version update. After installing beta 26 if you go to the about screen it shows version 24 not 26. On installation if I choose show configuration screen it shows correctly as 26, but after that if I go to about it shows as 24.
JRB
Post by JRB »
Hello Maksym, it seems on the screen saver selection page the selection points to the old version. I I open from C:\Program Files (x86)\Endless Slideshow Screensaver 2\Endless-Slideshow-2.exe then the version shows correctly but the selection from the screen saver settings page points to 24
Yes, you'll need to uninstall first and then do a clean install of version 2.0.0.26. Now you may have to manually remove the screensaver from your Windows folder after uninstalling. Simply find a .scr file and delete it.
JRB
Re: Endless Slideshow Screensaver 2 beta 2.0.0.29
Post by JRB »
Is there a whats new section for the beta versions?
Nope, sorry.
JRB
Post by JRB »
Hello Maksym. My question is about the metadata filtering. Is it possible to exclude pictures with keywords example (tim;Jane;) but also include pictures with certain keywords example ( Christmas;Winter; )? If not could this be a possible wish list?
Thank you.
Do you want to run a slideshow built only from the photos that have the Christmas or Winter tag excluding those that also have the tim or Jane tags? So, if the photo only has the Christmas tag - it will appear in the slideshow. And if the photo has both Christmas and Jane tags, then it's not going to make it into the list. Is that correct?
