Rule34.xxx Samples
ThuggaThuggin
Rule34.xxx Samples
Post by ThuggaThuggin »
Hello, I'm wondering if there is a way to make the program download the full image size, and NOT the sample size (i.e. sample_a67hdsbf7.jpg) with the rule34.xxx template. Great application otherwise
Re: Rule34.xxx Samples
The problem with this website is that some media has originals and some don't :( So I cannot completely block the samples in the template settings - you will get nothing for some tags. And if I leave the originals, then there will be duplicaes - both samples and originals.
