Only download a Picture in one Image format
scrolller
Post by scrolller »
Hello.
I am using this Software for a few days now to download from Scrolller.com which works great with the template i am using:
scrolller.com downloader
However, most pictures on the website are in both JPG and WEBP format, while some are only in JPG or WEBP.
To avoid duplicates my question is: is there a way to only download the same picture in one format (let's say JPG) if it's available in both?
They have the same filename except for the file extension/format.
Thanks in andvance
Re: Only download a Picture in one Image format
Unfortunately, that's impossible. If all the pictures were in both formats - that would have been easy, but when there are 3 options: only JPG, only WEBP, both - I do not see any way to filter some of the pictures out while still getting all of the unique ones.
I did update the template though to prevent smaller-resolution .webp images from downloading.
