Extreme Picture Finder only downloads 997 videos in one project (RedGifs)
jiar9
Post by jiar9 »
Hi, I'm using the template to download all uploads from a user on redgifs using this template: redgifs.com - user uploads template but it only downloads 997 at a time on a user that has over 6000 uploads. Does it have something to do with the template or is it because I only have the standard/trial version? Or is there a setting that prevents projects with over 1000 files?
I would appreciate any help
Regards,
jiar9
Re: Extreme Picture Finder only downloads 997 videos in one project (RedGifs)
Trial version does not limit this kind of downloads in any way. Did you remove the delay between downloads or used more than 3 simultaneous connections in your project?
jiar9
Post by jiar9 »
Maksym wrote: 03 Jun 2024, 11:16 Trial version does not limit this kind of downloads in any way. Did you remove the delay between downloads or used more than 3 simultaneous connections in your project?
No I left the settings as they were (3 simultaneous connections and 4 to 6 second delay between downloads). I didn't change anything.
And what's in the log? Does it show any errors?
jiar9
Post by jiar9 »
Maksym wrote: 04 Jun 2024, 12:47 And what's in the log? Does it show any errors?
Some of them say HTTP- Response "200 OK" and some with blank fields under HTTP Response. The Depth of most of the videos is 2. But four or five are Depth 1. Theres nothing in Socket errors or Filter.
And the project is in the "Finished" state with some addresses having blank fields under HTTP Response? That's not right... It's supposed to continue downloading until all addresses from the download log have values in the [HTTP response], [Socket error], or [Filter] field.
jiar9
Post by jiar9 »
Maksym wrote: 06 Jun 2024, 12:46 And the project is in the "Finished" state with some addresses having blank fields under HTTP Response? That's not right... It's supposed to continue downloading until all addresses from the download log have values in the [HTTP response], [Socket error], or [Filter] field.
But it looks like that for me. Three of them also have "503 Server Error" under [HTTP Response]. But Socket error and Filter are all blank.
Maybe the template doesn't work correctly (anymore) or is bugged?
The template seems to be just fine. Does this happen for every redgifs user on your PC?
jiar9
Post by jiar9 »
Maksym wrote: 07 Jun 2024, 11:57 The template seems to be just fine. Does this happen for every redgifs user on your PC?
Yes I tried two more users. It never downloads everything. On a user with 600+ videos it only downloads 390 for example..
Hmmm. Interesting. Does your log have those 503 response codes and, if it does, on what URLs?
