template has stoped downing loading files all files it gets to 600 and then stops when the site is showing 1,500 files or it shows it has download 392 but is has only done 206,
is there a setting I can change in the template?
FetLife template v15 not saving all files
Re: FetLife template v15 not saving all files
This is a Fetlife template not MetLife dam auto correct
Do you have any errors in the download log of your project? Any non-200 HTTP response codes?
no just that the project has competed not error codes
Hmmm. I'll try to find out what's going on.
