help with saint.to
Re: help with saint.to
OK, I updated the template(s). Please try the new version.
What did you change to make it work?
You should look at the page source to understand why one things work and others don't. You can do it by pressing [ Ctrl + U ] in your browser. The actual URLs used on that page are:
httрs://href.li/?httрs://saint2.su/embed/....
So I added a Custom Parser that uses the addresses that come after "httрs://anything.here/?".
Maksym where can i find the URL Code for Saint?
i cant find a tempalte either.
In your other post (which I accidentally disapproved, sorry about that) you said that you needed it for the celebforum, right? Can I see the full actual URL you want to download from?
haha no worries :D
https://celebforum.to/threads/ally03.76592/page-3
on this page u can see Vids uploaded on cyberdrop and also from saint.
When I open a project with the celebforum template these dont get downloaded.
So i have to download them manualy wich fails the point of using EPF :D
regards!
regards!
I did not see a single third-party link in this thread. Do I need a silver status in order to see them? If yes - send me your login/password to support@exisoftware.com
