Feature Suggestion - ffmpeg integration
Integrate ffmpeg for video downloads turning segmented videos from sites downloading m3u8 into mp4
Re: Feature Suggestion - ffmpeg integration
Hmm. OK, can you give more details? How do you see it? Right-click menu item in the file browser? Any options?
Id say go with whatever is easiest imo
Easiest - Segmented videos would have to be downloaded in its own folders. - Right Click Context menu
Complicated - Add an option in site exploration to use ffmpeg to combine detected segmented video files into mp4, scan folder and m3u8 verify segments match start to finish, notify if missing a segment
Right click context menu seems by far probably the easiest as you can batch the folders by the folder names along with output
OK, thank for the input. I think it can be done.
