Where are the templates saved?
Gr00t
Post by Gr00t »
Where are the templates saved, can they be backed up? That's my question, thank you very much...
Re: Where are the templates saved?
The templates are saved into the [ Templates ] sub-folder of the Extreme Picture Finder [ Data folder ]. You can see the location of the [ Data folder ] in the Extreme Picture Finder settings, [ Advanced ] section:
You can simply click the [ Open ] button to view the folder in Windows Explorer.
Gr00t
Post by Gr00t »
Ufff, thank you very much for your quick and clear response, greetings
