I am having issues with the all user galleries template on Imagefap, running the latest build 3.65.9.0 and template version 24. When the download finishes its like only the first set of the users galleries are downloaded but the subsequent pages of galleries (e.g. 2,3,4,5, etc) are ignored. I looked in the logs, but I am not sure I see anything and I have not figured out yet how to modify the templates well enough to see a workaround.
Thanks for any assistance.
Imagefap Template Issue? All User Galleries Template
Re: Imagefap Template Issue? All User Galleries Template
Can you give me the full exact URL you have problems with? It would be even better if you sent me your project's download log to support@exisoftware.com. You can find the log file using the [ Open download log file folder... ] button in the [ Project file ] section of the project properties.
