Text color, size and text background control
jimmyv4351
Post by jimmyv4351 »
Is there a way to set the text color, size, and background?
Also, do you have a projected date for the new version?
I'd previously asked about making ESS start from the right click menu with a selected folder and you said it would be in the next version.
Re: Text color, size and text background control
Yes, of course, there is. In the screensaver settings select [ Viewer ] tab, [ Text ] section. Then select the text you want to modify in the list and click the [ Edit ] button under the list. This will open a window where all available overlay text parameters (including color, size, and background) can be modified:
Well, the work on Endless Slideshow Screensaver 2.x is definitely being done. Here is what it looks like so far:
But I cannot tell when it's going to be ready. Not even approximately. Right now the slideshow is not even starting yet.
