Can't download only this folder
flugel
Post by flugel »
Is there a way to rip this folder https://www.bellazon.com/main/uploads without having to parse all the site?
After 200K urls crawled EPF goes very slow.
Re: Can't download only this folder
There is no access directly to this folder, so you will have to go through the pages to get direct links to images from that folder. I think you should use a lot of filters in the [ Excluded URLs ] to make the project work faster. Take a look at the download log, decide which URLs you do not need and filter them out.
Another option would be creating several project for different parts of the website - do not try to process a big website in one project.
flugel
Post by flugel »
Thank you.
