expedited loading?
InGearX
expedited loading?
Post by InGearX »
I see that Endless Slideshow Screensaver will first scan all the folders for all the files
but I have a library that is 500,000+ images
so takes a while :/
maybe 5+ minutes
is there anyway to hack it to make it just load anything it finds at first and then scan in the back ground?
and it would be nice to have a feature like that in the future
btw I already did
Settings > Slideshow > Shown picture history - checkmark [ X ] "Reset shows pictures history on start-up"
as I have had another alike problem like that - where it would take a very long time to load
see viewtopic.php?f=6&t=11120&p=14727#p14727
because my history file was 134MB big
in
C:\Users\YOUR-USERNAME\AppData\Local\Endless Slideshow Screensaver\history.dat
YES renaming it (removing it)
FIXED it
I renamed it manually but another option for users is to
Re: expedited loading?
Yes, there are plans to add the ability to read the picture list once, in the screensaver settings, and then just use it in the slideshow, without re-reading it every time.
