anyway to take a screenshot?
InGearX
Post by InGearX »
I have a 2x2 slides displaying across 3 monitors
from a library of 500k pictures
when I see some picture I'd like to reference later - is there anyway I can setup my Win 10 to take a screenshot?
I use ShareX - so I need to press a hot key - but that exits the screensaver
hmmm maybe some voice activated way via Amazon Alexa for PC or hmm any ideas?
thank you ...
Re: anyway to take a screenshot?
In the most recent version you can check the [ Exit only on [Esc] key, not on any other ] box in the screensaver settings, [ Viewer ] tab, [ Actions ] section to prevent Endless Slideshow Screensaver from existing on any key press except for the [ Esc ] key.
Plus, Endless Slideshow Screensaver Pro offers other ways to accomplish your task. You can copy all currently shown images into a selected folder on [ X ] key, for example. Or copy file names of all currently shown pictures to the Windows Clipboard on [ C ] key. You can even run a custom command or batch script with file names of all currently shown pictures on keys [ 1 ] - [ 5 ].
InGearX
Post by InGearX »
awesome
thank you
I'm glad I asked
PS UPDATE: Hmm ShareX fails to take a screenshot when screensaver is running
I guess Windows or Endless Slideshow Screensaver doesn't let the keys pass through?
works OK when I test in "Preview" mode
hmmm any ideas?
thank you
UPDATE 2: Looks like only Win native Print Screen button worked - Ditto (clipboard manager) registered two screenshots - one of all 3 monitors and another for the main monitor or for where the mouse is
but they were not saved to files - which is not ideal
only to clipboard
I had to go to run>cmd: "mspaint.exe" and paste them there
Endless Slideshow Screensaver does not prevent any keys from working. That must be exclusively ShareX's problem.
