Greetings to all, I installed Extreme Picture Finder (Version - 3.62.2) on Windows 10 computer last week. In general, for the first few days I was working fine, but since yesterday night I received this error message "Unable to make changes to your software" while working on this. Then I searched online and came across this particular post and I used this exact command from there
%ComSpec%="C:\WINDOWS\COMMAND.COM
Nevertheless, I'm getting the same error message. I really have no idea what to do. Should I need to use other methods which mentioned in the article? I am utterly confused, please help me.
Having Trouble While Working On Extreme Picture Finder!
Re: Having Trouble While Working On Extreme Picture Finder!
Well, as the post clearly shows - the problem lies outside the program, somewhere in your Windows. Plus, you have already been successfully using the program for a few days, which also proves that the problem is not in the program. I can suggest re-installation. Uninstall first, the re-download and re-install:
