A couple reddit issues
iamanepfuser
Post by iamanepfuser »
Just created a new project using reddit user template. EPF downloaded gifs as .mp4.gif & I can't open the file unless I change it to just .mp4.
Also, reddit templates won't download imgur .gifv links.
Re: A couple reddit issues
Can you provide sample URLs please?
iamanepfuser
the user I'm trying to download is https://www.reddit.com/user/flatlacroix2
an example gif link https://www.reddit.com/user/flatlacroix ... h_tonight/ will pull from https://preview.redd.it/9wsiak4jzjc81.g ... b279374d86 and download the .mp4 but title it 9wsiak4jzjc81.mp4.gif rather than pull from https://i.redd.it/9wsiak4jzjc81.gif
for .gifv if you try looking at https://www.reddit.com/r/CasualJiggles/ you'll see a bunch of i.imgur.com/xxxxx.gifv links are skipped. I also just noticed a couple of imgur.com/xxxxx links get skipped as well.
OK, I updated sub-reddit and user templates:
reddit.com - user template
www.reddit.com - download subreddit images
.gifv files are downloaded and saved as .mp4 now.
You can try all of the above now.
Also a bug in file naming was fixed so in the next release there will be no ".mp4.gif" files.
iamanepfuser
Good news, bad news
.gifv to .mp4 looks good, hooray
.mp4.gif still being downloaded
updated EPF to 3.59.2 and reddit subreddit template to v20 and user template to v8
Also imgur.com/xxxxx links should be processed properly with the updated templates.
That's going to work properly only starting with 3.59.3. It'll be released next week most likely.
iamanepfuser
Maxim wrote: 22 Jan 2022, 14:59 Also imgur.com/xxxxx links should be processed properly with the updated templates.
Okay, cool. A little off topic, but do I still need to re-do the project (delete old project, then create new project) if the templates been updated? There was mention about trying to not have to do that but I didn't see anything in the version changelogs.
It's not implemented yet, so you do have to create a new project with the new version of template.
OK, now the "mp4.gif" problem should be solved - please download and install version 3.59.3:
iamanepfuser
Maxim wrote: 24 Jan 2022, 18:02 OK, now the "mp4.gif" problem should be solved - please download and install version 3.59.3:
Look good, thanks
