Image Download from Imagetwist with Random Pics
Lolfreak
Post by Lolfreak »
Hello I wonder if it is possible to download the entire images from ex. https://imagetwist.com/?op=rand_file&usr_id=140401 and save them in a folder to ex. 140401
The downloadstrucktur is also as ex. https://img119.imagetwist.com/i/40xxx/u ... g/0005.jpg
However, I can't get EPF to save it in the /40xxx folder.
Can someone enlighten me here?
Thanks in advance!
Re: Image Download from Imagetwist with Random Pics
In the project properties select [Save - Sub-folders] section, [Expert] tab and check [Use Target file Parent URL RE...] box. I think this expression should work:
Expression: \.com/i/(\d+)/
Result: [#1]
Lolfreak
Post by Lolfreak »
Hi ,
first of all thanks for the fix support.
Unfortunately it still loads into the same folder
Although he /08716/ & /40037/ or /22049/
https://img27.imagetwist.com/i/22049/ir ... pg/038.jpg
https://img151.imagetwist.com/i/08716/6 ... pg/002.jpg
https://img165.imagetwist.com/i/40037/2 ... g/0083.jpg
downloadet, so I get 3x 090.jpg as example
Oh, those are direct file URLs... Then check the [Use Target file URL RE...] box add the same Regular Expression and add the same expression to the corresponding list.
Lolfreak
Post by Lolfreak »
Thank you Maxim that works very well!
I have another question should I make a new post for it?
BR
Yes, make a new post, please.
