Screensaver permanently stuck on first photo
OlfOlfson
Post by OlfOlfson » 03 May 2021, 15:04
For some reason after working as it should for one time now the screensaver is stuck on the first photo it shows.
The preview does the same. It's always another photo, so the program obviously is able to comb through the plethora of folders I told it to.
I've already done a clean uninstall and re-install including manually deleting the folder in AppData as suggested in another thread but to no avail.
Re: Screensaver permanently stuck on first photo
Post by Maxim » 04 May 2021, 12:12
What about "left arrow", "right arrow" buttons? Do they work? Do they advance the slideshow?
OlfOlfson
Post by OlfOlfson » 04 May 2021, 19:26
Ha, knew I would find the solution as soon as I'd have written the thread, sorry.
I had "activate image transitions" (or however it's called in the English version) unchecked,
leading to the program not transitioning to any new image at all.
A bit counterintuitive imho but happy that it works now.
(left and right arrows didn't work by the way but didn't end the one-image-slideshow as any other key did)
