reddit albums
iamanepfuser
Re: reddit albums
Post by iamanepfuser » 08 Dec 2020, 17:37
Maxim wrote:
08 Dec 2020, 13:37
Well, apparently you cannot mix both types of URLs in one project. You should create project with either /gallery/ or /comment/ URLs. If you combine them - /comment/ URLs won't work.
I think we're having a misunderstanding. I cannot get EPF to download anything if I use a "/comment/" link. However, if I use a "/gallery/" link it works fine. Separate projects/instances. The template page says the template should work on either "/comment" links or "/gallery/" links but I can only get it to work if I use the "/gallery/" link.
Using my previous link examples, start a project using the /comment/ link and I get nothing but the "Target files not saved" pop up. Then start another separate project using the /gallery/ link and I get all 6 pictures.
And when I use the /comment/ link the project wizard defaults to "download subreddit images" template but when I use the /gallery/ link the wizard picks "gallery" template. I've never had EPF choose the wrong template before.
Re: reddit albums
Post by Maxim » 08 Dec 2020, 17:51
Oh, you HAVE to choose the correct template manually for the /comment/ link in order for EPF to work correctly.
iamanepfuser
Re: reddit albums
Post by iamanepfuser » 08 Dec 2020, 18:01
Maxim wrote:
08 Dec 2020, 17:51
Again I don't think you're understanding, I can not get the /comment/ link to work. I did change to the gallery template and EPF didn't download anything. My comment about EPF not picking the correct template is a separate issue I am letting you know about because I have never seen EPF not pick the correct template.
Re: reddit albums
Post by Maxim » 08 Dec 2020, 18:10
What version of the program do you have?
iamanepfuser
Re: reddit albums
Post by iamanepfuser » 08 Dec 2020, 18:50
newest/current 3.52.1
Re: reddit albums
Post by Maxim » 08 Dec 2020, 19:02
So, you create a project with "https://www.reddit.com/r/AlbumBabes/com ... 6_nonnude/" as a Starting URL, click "Next > " and select the
www.reddit.com - gallery template
click "Finish", start the project. Then the built-in browser pops-up, you see the page with the first photo shown in it, click [ Continue download ] button and receive a [ No Target Files were saved ] message?
iamanepfuser
Re: reddit albums
Post by iamanepfuser » 08 Dec 2020, 19:36
yes
Re: reddit albums
Post by Maxim » 08 Dec 2020, 20:38
Are you signed-in in the built-in browser or you just clicked "I'm 18+"? Do you see that "18+" warning?
iamanepfuser
Re: reddit albums
Post by iamanepfuser » 08 Dec 2020, 21:06
When I/we first started this I was signed in. I tried "delete cookies and reload" and signed in again but still got "target files not saved".
Re: reddit albums
Post by Maxim » 09 Dec 2020, 11:33
This is weird :( I don't understand. It works perfectly for me. What if you use a generic built-in template "Download all images from sigle-page gallery" with /comments/ URL and [ Manual login ]?
