template for https://hindi-fonts.com/fonts/
smith
Post by smith »
Hai Maxim
Can please helm me to download all fonts which are in archive file please make template for me
Thank you
Re: template for https://hindi-fonts.com/fonts/
You can't. This site uses reCaptcha :(
bowu
Post by bowu »
I didn't make you a template.
However I did index all of the fonts using an automation I made.
(Which ended up indexing 976 fonts)
Font list [.txt]
The .zip path only works on an IP/Cookie (haven't tested which) that has passed the reCaptcha and other checks on download button click.
My suggestion would be to create a program using puppeteer, selenium, or some other automation, to pass through the checks, then proceed to download.
https://github.com/berstend/puppeteer-extra/ is what I generally use with NodeJS to bypass some checks
If you don't want to make it in NodeJS, and rather in Go Lang or any other as long as you inject JS before the page etc...
Check out this, compile it, https://github.com/go-rod/bypass/
I compiled it using the go-rod/bypass, here's a already compiled version as of [10/28/2020] https://pastebin.com/mKjvp5H9
-- Sorry that I wasn't very helpful.
