Screen Saver Works but Not Always!
ralft
Re: Screen Saver Works but Not Always!
Post by ralft » 29 Oct 2020, 00:29
In my main PC where SS is working, there are 5 Endless Slideshow Screensaver files. In the PC which SS will not run, there are only 3 files and they remain even after uninstalling it. After reinstalling it will work only until I change the settings to show where my photos are stored.
Post by Maxim » 29 Oct 2020, 12:44
OK, maybe that is the problem. Do you have your photos on the same PC where screensaver is running?
ralft
Post by ralft » 29 Oct 2020, 17:36
How do I send you photos
Post by Maxim » 29 Oct 2020, 17:57
Send them as attachments to support@exisoftware.com
ralft
Post by ralft » 30 Oct 2020, 03:10
email didn't work
Post by Maxim » 30 Oct 2020, 19:10
What do you mean? How can email not work?
ralft
Post by ralft » 31 Oct 2020, 00:37
They came back to me marked undeliverable on 10/29/2020, 6:21 PM but perhaps they have been delivered since then. Please check
Post by Maxim » 31 Oct 2020, 12:55
Is there a chance that you made a mistake in the email address? Did you just copy it from the page or typed it in manually?
ralft
Post by ralft » 31 Oct 2020, 23:25
Here is a copy of what I copied from your post:
Maxim Reva <support@exisoftware.com>
I will try resending now.
ralft
Post by ralft » 03 Nov 2020, 23:47
Again the email failed to go thru.
