Auto click "continue download" button?
Hi! I've setup many projects to run next project after completion of the previous one. The problem is that I have to manually login first time because automatic login doesn't work. So every time when next project starts, I have to see and press "Continue Download" button for the project to start. Is there any way to bypass this and start the projects automatically?
Re: Auto click "continue download" button?
Currently you cannot do that. That's why it is "Manual" login in the first place. But if all your projects are downloading from the same domain - you can try to add all your starting URLs to one project. This way you'll have to use Manual login only once when you start the project.
I did that but it only downloads first url from addresses and then stops for some reason.
OK, I'll add this option to the to-do list.
Thank you very much!
