Template for girlsreleased no longer working
funkynut
Post by funkynut » 18 Aug 2019, 02:07
Was using the template then it stopped working.
Looks like it isn't able to run the scripts required to generate the images.
Re: Template for girlsreleased no longer working
Post by Maxim » 18 Aug 2019, 14:48
That's right. They updated their main JavaScript which generates the image links and now it doesn't work in Internet Explorer which is used as a built-in browser in Extreme Picture Finder. So, until this is fixed Extreme Picture Finder cannot download from this website. We added this information to the template description. So all we can do is ask the website owners to make their JavaScript support IE.
funkynut
Post by funkynut » 18 Aug 2019, 21:55
Bummer.
Thanks for the update!
fff1f
Post by fff1f » 05 Sep 2019, 18:54
As a workaround, you can use the Palemoon web browser along with the Image host grabber extension to download from Girlsreleased.
