Need help with newtumbl.com template
RawRanger
Post by RawRanger »
newtumbl.com is pretty much a Tumblr knockoff. So I tried editing the Tumbr template to make it work on Newtumbl as well. It seems to almost work, but whereas the Tumblr HTML login works, the HTML login of Newtumbl does not. The browser popup to enter your login data appears, but is frozen. You cannot interact with it, so logging in is impossible. I've tried 3 different browsers all WITH the same result. Does anyone here know how to fix this? Thanks!
Re: Need help with newtumbl.com template
If login doesn't work then how Extreme Picture Finder can work with it?
RawRanger
Post by RawRanger »
It's not the login that does not work. The login works fine in any browser. The only time it does not work is when it pops up in the browser-like window from Extreme Picture Finder. Here's a screen shot:
https://ibb.co/NFfnnJm
Although you get the login screen appears OK, you cannot interact with it. No text entering or link referrals. It's frozen like it is a picture.
Do you have the most recent version of Internet Explorer installed? Extreme Picture Finder uses it as a built-in browser, so it needs to be updated to the most recent version.
If you do have the latest IE and it still does not work - means that website does not support IE and in this case Extreme Picture Finder cannot do the job here.
