Add Path Name to Filename
JT-TayFHC
Post by JT-TayFHC » 18 Dec 2018, 02:38
Please add the name of the path to the front of the filename. My filenames are too generic (camera-generated) to know when/where/what folder the photo came from. I organize all my photos into a well-named set of paths. Don't need the whole path, just the current folder and the previous folder name.
Is this already in the Pro version?
Re: Add Path Name to Filename
Post by Maxim » 18 Dec 2018, 13:17
You can display the full path to the current photo even in the free version. You can do in the screensaver settings, Viewer tab, Text section. Here is a generic tutorial on using viewer text:
https://www.free-photo-screensaver.com/faq/#q7
In the Pro version you can also display the name of the folder where current picture is stored as well as a lot of other useful picture information including meta data (EXIF and IPTC).
ralft
Post by ralft » 22 Feb 2020, 00:41
Since upgrading/replacing both of my Win10 computers I have had difficulties. The latest is with the photo's file info. In one computer it shows #ttPictureFileName instead of the actual file name. In the other it shows nothing. In the settings for Viewer/Text I have [#ttPictureFileName} after eliminating NoPath#. What is the correct setting to always show the file name with its path?
Also, I have no luck with emails getting through to Maxim Reva who has helped me in the past.
Post by Maxim » 22 Feb 2020, 11:34
Yes, we're having problems with the hosting right now. We're working on it.
The correct text tag is:
[#ttPictureFullFileName#]
You can use the drop-down list in the [ Special tag ] section to select correct tags and [ Insert special tag ] button to use them without typing.
