I need help downloading from imagefap.com
oldmanho
Post by oldmanho » 07 Nov 2017, 06:15
I am trying to download from imagefap.com specifically here:
http://www.imagefap.com/organizer/169348/Holes
http://www.imagefap.com/profile/bambouX/galleries
using the template from here:
The project starts an i see this
[Downloading... Processed 0 of 1 addresses]
No images are found and i get the error message:
[Your project finished but zero target files were saved. All starting addresses in the project returned the same HTTP error code: 404. Please go to the project options and make sure you entered correct starting addresses.]
These are the regular expressions in the template
/pictures/([a-zA-Z0-9]+)/([^\?\/#]+)
Re: I need help downloading from imagefap.com
Post by Maxim » 07 Nov 2017, 11:00
You're using the wrong template. Please use this template to download all galleries from user profile:
imagefap.com - all user galleries template
Or this template to download all galleries from any folder inside imagefap.com user profile:
imagefap.com - all galleries from a folder in user profile
