Can you add a Date Version to Project Templates?
Aristotle
Post by Aristotle » 29 Sep 2017, 11:44
I never know if they are updated.
Re: Can you add a Date Version to Project Templates?
Post by Maxim » 29 Sep 2017, 14:58
Most recent version of Extreme Picture Finder checks for new versions of downloaded templates daily. So, first of all, please download and install the most recent version of the program:
http://www.webimagedownloader.com/download/
You can change the verification period in program settings. And the program is supposed to warn you when you are trying to create a new project using an outdated template like this:
So please open Extreme Picture Finder settings using menu item Tools -> Settings..., select the Online database section and check all necessary boxes:
Plus you can always check for template updates manually in Extreme Picture Finder's Local templates library window. You can open it using menu item Templates -> Open local templates library... and then, in this window, select menu item Library -> Check downloaded templates for updates:
Outdated templates are marked with red warning saying that new version is available. Now you can right-click any template and select View template page item in the pop-up menu. It will open your default browser and point it to the template page in the database where you can re-download the updated template and install the new version.
Finally, you can periodically check this page:
http://www.webimagedownloader.com/templates/new/
which shows 10 recently added or updated templates.
