Using found in source string as link
szprot5
Post by szprot5 » 31 Jul 2017, 18:59
I want my project to find "hidden" links in classes <a> etc. etc. the links are just nice looking full urls that sadly are missed when i run my project.
How can i make that thing work?
Example. i want to check whole html source for *messages/t/* fragment and if it finds that - copy whole url and use it to go deeper.
Best Regards
Jacek
Re: Using found in source string as link
Post by Maxim » 01 Aug 2017, 11:09
Hello Jacek,
This is what "Custom Parsers" are there for. They are used to create URLs from page text. If your links are inside attributes of any tag, like this:
<a href="#" some-attribute="http://full-url">some text or image here</a>
then you should create the following Custom Parser:
Expression: some-attrbitute="([^"]+)"
Result: [#1]
This Expression means: take all text that starts after
some-attrbitute="
contains 1 or more symbol that is not "
and finishes before the first occurrence of "
In this case the result will be:
http://full-url
If you give me a piece of real page text - I'll create exact parser that will do the job for you.
