Watching pictures from 2 folders on 2 monitors (1 folder for 1 monitor)
chu
Post by chu » 27 Apr 2017, 18:06
Hi, I have try to run endless slideshow on 2 monitors at the same time. Program works perfect.
There is one option which I want to use but can't get it to work.
What I want to get: I would like to see pictures from the local folder #1 on monitor #1 and pictures from the local folder #2 on monitor #2.
I have tried to use Aster program which allows to make 2 virtual independent PC's based on one PC's hardware.
It didn't work out.
Please let me know if it's possible to watch pictures from 2 different folders on 2 different monitors (1 monitor for 1 folder).
Thanks.
Re: Watching pictures from 2 folders on 2 monitors (1 folder for 1 monitor)
Post by Maxim » 01 May 2017, 20:41
Currently it's not possible with Endless Slideshow Screensaver. Sorry. But we do have plans on extending the multi-monitor support in various ways in future releases.
chu
Post by chu » 15 May 2017, 05:56
SOLVED, SOLVED, SOLVED.
Thanks for reply.
Problem is solved.
It is necessary to install ASTER, which makes 2 independent virtual comps (work places) out of one hardware comp. Should be 2 accounts created. Each account works with its own monitor. Endless slideshow should be installed on both accounts independently. And you will be able to run both independently.
ASTER allows create several independent work places out of one hardware computer. Everything depends on installed: video card, CPU, HDD, ram.
Ive got: dell 960, CPU 2.6ghz, 3gb ram, 1tb HDD, integrated video card with vga and display port outs. It works on 2 monitors for pictures only.
Each monitor shows pictures from its own folder.
Everything runs perfect.
Thanks.
Post by Maxim » 15 May 2017, 11:22
OK, thanks for letting me know
