recover offscreen window
richardn
Post by richardn » 25 Feb 2017, 17:39
Whenever I switch from multiple displays back to just laptop display, I lose my EPF windows.
No matter what I try, they appear offscreen. Changing resolution, cascading windows, etc., don't work. If I do a <shift> right click as recommended by windows, "Move" is not one of the options that shows up.
Is there a way to correct this, or am I stuck now only being able to use EPF when I'm connected to an external monitor?
Please advise.
Re: recover offscreen window
Post by Maxim » 27 Feb 2017, 12:59
Hmm. OK. This one needs to be fixed. Thank you for reporting this problem.
richardn
Post by richardn » 27 Feb 2017, 16:20
Appreciate the quick response. I'll be watching new releases for the fix.
Thanks!
Post by Maxim » 01 Mar 2017, 12:15
OK, please try the new version. Now all program windows should position themselves correctly:
