Settings to Eliminate Duplicate downloading
Nimzer
Post by Nimzer » 13 Nov 2016, 08:53
Heyo! This one's giving me some trouble and I don't see an obvious solution.
the site is:
http://wallpapershome.com/nature/
Just interested in some of the pics from this gallery (nature), but when I try to specify that it only download the files with a width of >3000 pixels, it ends up downloading a bunch of duplicates.
Even though the names of the downloaded files show they should be different sizes, this is not the case.
Any help would be greatly appreciated, but do not spend much time on this, it's just puzzling me more than anything.
Nimzer
Re: Settings to Eliminate Duplicate downloading
Post by Nimzer » 13 Nov 2016, 20:58
Alrighty I figured out some settings using the target files set to only download
*5???x????*.jp*
*4???x????*.jp*
So that I only download the images copies that are 4000-6000 width resolution.
Problem has been solved
Post by Maxim » 13 Nov 2016, 21:10
I'll create a template for this website tomorrow. It will download only original-sized wallpapers. I'll post a link to the template here.
Post by Maxim » 14 Nov 2016, 14:05
OK, here is the template:
I used "Filters -> Excluded page parts" to eliminate links to all duplicate (resized) wallpapers, so you will get only original-sized wallpapers and EPF will not even try to download anything else.
