imagefap download galleries from user
joeblow
Post by joeblow »
how do you download all galleries from a specific imagefap user?
Re: imagefap download galleries from user
Here is the template for this:
It works for URLs like this:
http://www.imagefap.com/profile/XXXXXXXXX/galleries
just like the imagefap.com gallery template. The tutorial for galleries is here:
http://www.webimagedownloader.com/how-t ... ownloader/
You have to do exactly as described in this tutorial, but with the above template.
joeblow
Post by joeblow »
thank you very much, it' helped!
What I like about this template the most - is the way EPF stores each gallery in separate folder. And the folder has the name of the gallery. Very convenient. I don't think there is a software out there that comes close to this one.
