64 Bit Version
utomo
64 Bit Version
Post by utomo »
Hello Maxim,
Is there any plan for 64 bit version ?
do we will get speed or other improvements ?
Re: 64 Bit Version
Nope. What's wrong with 32-bit one? Working just fine on any 64-bit Windows.
Other improvement are coming soon. That's for sure.
utomo
Re: 64 Bit Version
Post by utomo »
Thanks maxim
I did not have problems running on 64 bit computer too.
and also EPF never use memory big enough. it only use XX MB.
is that possible to allocate bigger memory for faster processing ?
Re: 64 Bit Version
It won't help. EPF takes the memory when it downloads the file... Once the file is saved - the memory is released. EPF simply doesn't need a lot of memory to operate.
I think the page parsing algorythm can be improved to speed up processing... I'll see what can be done.
