Limits | Results number
AdrianH
Post by AdrianH »
In Search Properties | Limits | Results Number, how do I set this to unlimited (or at least more than 1000 which seems to be the forced limit).
Thans
Re: Limits | Results number
Yes, you're right. 1000 images per search engine is currently the limit. And usually there are fewer RELEVANT search results. Some engines won't provide 1000 results for some keywords. So we decided to limit the results number to 1000/engine = 5000 images per keyword.
Do you really need more?
AdrianH
Post by AdrianH »
Yes, I have run into the limit a couple of times while still getting relevant results. Couldn't you have a check box like the other limits (or set a higher limit or set 0 = infinite?) please?
Thanks!
OK, we'll increase the limit.
AdrianH
Post by AdrianH »
Thank you!!! :-) :-)
