Make these properties default for all searches
This button is not working in the 3.25.0.0 version. At least not for me, it won't save the minimum resolution settings, I have to set it for each and every search.
Re: Make these properties default for all searches
OK, thanks for the report. Gonna fix it and let you know when it's done.
The problem is solved. Please download and install version 3.25.1.0:
That was amazingly fast and I can confirm that it is indeed fixed. Thank you!
