Endless Slideshow Screensaver 2 beta
Re: Endless Slideshow Screensaver 2 beta
I added some bug reporting to the most recent beta. Please download and install it:
Download Endless Slideshow Screensaver
JRB
Post by JRB »
So far so good. Since installing this version with the bug reporting endless has not had the error so far.
I'm really glad to hear that!
dekadetia
Post by dekadetia »
Is it possible to turn off all the loading text? "Starting the slideshow" and "Creating the first slide" and so forth? The screensaver would be a lot cleaner without it.
Right now it's impossible. Why is this a problem for you? It's shown for just a second or so... Otherwise it's just a black screen without any progress indication.
dekadetia
Post by dekadetia »
Maksym wrote: 22 Jan 2025, 12:40 Right now it's impossible. Why is this a problem for you? It's shown for just a second or so... Otherwise it's just a black screen without any progress indication.
For me it's a problem because a screensaver is meant to simply start, not to report on what its doing. It would be great to have the option to hide this part of the process. Are those loading texts stored in JPGs or actual text? What invokes them?
You do understand that hiding those texts won't make the screensaver start any faster, do you? It will still need time to initialize, but during that time you'll see a black screen.
dekadetia
Post by dekadetia »
I absolutely do. Would still be a great thing to be able to toggle off. My screensavers only take a second or two to start up and I run windows from a black wallpaper to a 77 inch screen -- the smooth transition is worth it to me.
OK, I understand. I'll add this option.
OK, this option is available in Endless Slideshow Screensaver 2.0.0.40:
You can download it here:
Please try it and let me know if it works for you.
