Thanks maxim. I will try it tomorrow.
How about the normal slide / PowerPoint download?
What setting I must use?
New Version
Re: New Version
Just exclude everything and include only required URLs. As always.
Re: New Version
Thanks Maxim,Maxim wrote:Well, I created a template project. You can download it here:
http://www.exisoftware.com/downloads/pi ... mplate.exe
So, you download and run the above template. It'll create a new category and a new project in your project tree:
slideshare.net -> slideshare.net - template
You simply clone this project (menu command Project->Clone project...) and in the newly created project clone you set the starting address and a destination folder. That's it.
I try this and it download the swf. I still did not try to convert the SWF yet to JPG
I have suggestion for version 4.
Instead of using Exe file for creating project like this.
How about adding features to Load project files. and others. so we can easily share the project files on the forum too.
Re: New Version
Yeah, I have plans to make "templates" available in the "New Project Wizard". Also I plan to allow users share their projects via built-in database directly.
Re: New Version
Wow. Look interesting.
When I can try the beta version?
Re: New Version
I try to download ppt, pptx and pdf files
start from http://www.slideshare.net/most-liked/la ... mgmt/month
But I did not getting any file.
I try using the html login.
Please check and help. Thanks
Re: New Version
Well, send your login/password to support@exisoftware.com and I'll try to help.
Re: New Version
Thanks Maxim, I already send it to your email.
Re: New Version
OK, looks like EPF can not log into this website. I'll have to find out why.
