Just think like Antivirus deliver the data update. Without need to reinstall the software.
But it always up to date
New Version
Re: New Version
Yes, I understand your idea.
Re: New Version
Maxim, can you check the final version.
I experience Hang/ not responding. for long time.
Re: New Version
Working on it right now.
Re: New Version
Thanks.
If you need something, such as log files, please let me know
Re: New Version
OK, thanks. I'll let you know if I need more information.
Re: New Version
By the way, the settings of this "cupcakes" search will help. Did you use the min. image height or min. image width option? Send me the project file of this search if you can.
Re: New Version
I already sent it to your email.
minimum file size 50
BTW after force close the image counter is missing
But the images still there
Re: New Version
That's right. The image counter is saved only when the download is stopped normally...
Re: New Version
do you got the email ?
any other things needed ?
I am not in hurry, take times. to create stable next version
