When we Hit the Close button X
1. better to give warning/ dialogue box yes / No
2. The counter saved. now the counter is resetted
New Version
Re: New Version
I try to run EPF using maximum setting 30 connection and it really stable now.
mostly CPU consuming only around 20%
Memory consumption also around 60-70.000K
Good job maxim
Good job maxim
Re: New Version
Thank you very much utomo! Now I'm working to add even more speed to big projects (10,000+ files) and project with more than 1,000 starting addresses (already working MUCH faster in the beta version).
Re: New Version
Hello utomo! Here is another beta version:
http://www.exisoftware.com/downloads/pi ... rSetup.exe
It is supposed to work much much faster than any previous version. Plus it shows total number of addresses in the queue and the index of currently downloaded address.
Re: New Version
Thank maxim.
Beside the speed, what's else new?
Re: New Version
The speed alone took me a lot of time. It's much harder to improve anything then to create something new.Plus it shows total number of addresses in the queue and the index of currently downloaded address.
Re: New Version
we need the software in spanish in the future version
Re: New Version
I already try it. Yes it is faster.
It consume memory little bit bigger (from 60-70.000 to 100.000K). But I think still OK (Not too big)
But after few moments it grow : (Note I am Downloading MP3 from xeno canto)
to 200.000K. (downloading 1700 of 1)
to 300.000K (downloading 2770 of 1)
Please check this if it is Ok or Not
But I am little bit confuse with the meaning of this
Downloading address XXX of YYY
example :
Downloading address 348 of 1
example :
Re: New Version
But then it going down again
Downloading 3977 of 1
memory usage 62.000K
Re: New Version
OK, I'll check the counter. Thanks for the feedback!
