Yes, that would seem to be the answer, however....
I have attempted this several times, your standard find a string pattern with regex, parse the output sections into an array, then take the desired section and manipulate to create an input string that it can use to access the actual picture. Use regex allot with my job, simple ones for grep'ing through files. So I do get how it is assumed to work.
I can repeat the behavior for you. I will capture my configuration and send via e-mail, don't want to messy up the forums. And several sites, not just one or one type. I am sure this must be a simple user error with a comma or some setting I am overlooking. Basicly, all attempts to "replace" sections of the URL result in very spotty success.
And a new issue arose, When I right click on a project to verify and or edit the directives I can see my custom regex. When I click edit, nothing is there. I can cancel close-reopen EPF and the issue persists.
Again I can tell you I rarely buy software, I cannot remember the last time. I will re-new come Nov, and recommend this to friends. The ONLY(because there is nothing close to features) alternative is wget, and I really don't want to spend that kind of time writing out a script for each site. Ahh the old days when we had that kind of time.
Problem downloading HiRez images and dynamic links..
Re: Problem downloading HiRez images and dynamic links..
Hmm. OK, send your requests to support@exisoftware.com. Preferably with actual page URLs and the desired image URLs that you're trying to construct with Reg. Ex.
Did you select the it in the list before editing?
You have to select the Reg. Ex. you wish to edit and then click the "Edit..." button. Like this:And a new issue arose, When I right click on a project to verify and or edit the directives I can see my custom regex. When I click edit, nothing is there. I can cancel close-reopen EPF and the issue persists.
Thank you for your kind words. Also I'm ready to help you with any issues you may have and improve the software even further using any feedback you may provide.Again I can tell you I rarely buy software, I cannot remember the last time. I will re-new come Nov, and recommend this to friends. The ONLY(because there is nothing close to features) alternative is wget, and I really don't want to spend that kind of time writing out a script for each site. Ahh the old days when we had that kind of time.
