Simpcity & Bunker.fi album
Aliengirls
Re: Simpcity & Bunker.fi album
Post by Aliengirls »
Yes i also tried with other ones that have the problem and this big album is always downloaded :(
Gosh. OK, in this case, find that album address in your donwload log, right-click it and select [ Go to refering URL ]. Then give me that URL.
Aliengirls
Hello
I have :
In https://simpcity.su/threads/abigail-ratchford.15937/
GET : https://bunkr.cr/a/D1wKM7wy
Parent adress : https://bunkr.cr/f/idY2vj8nQFimX
in https://simpcity.su/threads/anissa-kate.18384/
GET : https://bunkr.media/a/D1wKM7wy
Parent adress : https://bunkr.media/f/c2IrvbTvw9D5W
In others for exemple :
get : https://bunkr.cr/a/D1wKM7wy
parent : https://bunkr.cr/f/gwHT5RewCwJ9r
in another one i have even a couple of it
get : https://bunkr.ph/a/D1wKM7wy
parent : https://bunkr.ph/f/x53fTWfvkNhsJ
get : https://bunkr.fi/a/D1wKM7wy
parent : https://bunkr.fi/f/BXV6PCgxeJ5nz
get : https://bunkr.media/a/D1wKM7wy
parent : https://bunkr.media/f/2gPgZPwFrek9N
Is there a way to avoid the soft to "see" D1wKM7wy key word or i dunno ? Because its seems this link is very mirrored
Its crazy its like its always a new link
OK, that helped. Please re-download the tempalte, create a new project and bring me the good news!
Aliengirls
Nice ! Tried, and it seems to work ! Thanks :D
Is there a way to update previous projects with the new template ? Or something to add in the previous one ? Or i need to restart from 0 ?
If your previous project(s) already found a link to that album, then the only way is to re-create and start from 0. Otherwise, you can replace one of the filters in the [ Excluded Page Parts ] of your project (compare the filters in the new and old versions, normally it's the first one).
Aliengirls
Ty, i did it and yeah it seems to work well now :D
