Hi, first of all: Great screensaver!
But there is one thing that bothers me: There is a thin grey line on top of my screen when the screensaver is running. This is visible if I disable the file info bar and have a dark background color set.
Grey line
Re: Grey line
Please download the latest version of Endless Slideshow Screensaver from our website:
http://www.exisoftware.com/slideshow-sc ... _setup.exe
Then install it and tell me if the problem fixed.
Re: Grey line
The grey line is gone. Perfect! You are very fast!
Thanks.
Thanks.
Re: Grey line
OK, great. Is there anything else you'd like to be added/fixed in the screensaver?
Re: Grey line
Hi again.
Actually there is one more thing, but its probably a bigger job to fix.
I have a computer connected to a Panasonic plasma tv with non square pixels. its 1024x768 (a 4:3 resolution) but the tv is wide screen, so everything looks streched there. But the videoplayers i am using have a option for correcting this. (zoomplayer and windows mediaplayer) Is it possible to add this option for your screensaver?
If you manage to add this option i`m sure your screensaver would be the first choice for every plasma tv user with non square pixels. I dont think there is any screensaver with this option.
Thanks.
Thanks.
Re: Grey line
OK, I'll see what can be done about it. Thank you for reporting it.
