Screen Saver Works but Not Always!
This screensaver/slideshow is just what I was looking for but it doesn't always startup reliably for me I don't really think this is a problem with "Endless Slideshow Screensaver", but rather a Windows problem. Sometimes it works after a period of inactivity other times not, even if the computer has not been active for a *long* time. I've double checked the Windows settings, registry, etc and everything looks ok. My hypothesis is that something is running that Windows 10 interprets as user activity. I've been trying to track it down but so far to no avail. Has anyone else experienced this kind of problem and give me an idea of where to look? I've been thinking of writing my own "activity-checker" service which would start "Endless Slideshow Screensaver" after i.e. mimic built-in mechanism, but I'm not sure exactly where to begin. Obviously this is not the preferred path!
Thanks in advance!
cs
Thanks in advance!
cs
Re: Screen Saver Works but Not Always!
Have you tried re-installing the screensaver? It does help in some situations.
I also have problems especially the computer which had an older version. With the newest version it mostly will not run. With my main PC it locks up on a random photo without any of the selected txt. When that happens it is totally unresponsive to the mouse or key strokes. But ctrl - alt- delete wakes the PC up again.
Yes, the screensaver does have a problem on some PCs when the it stops responding to mouse and will not continue the slideshow... You can use Alt+F4 to close the screensaver immediately in this case.
Now the PC that used to work fine with the older version will not work at all with the latest ver. My main PC is working fine since I deleted all the wallpaper selections. Any suggestions?
Try a clean re-installation. Uninstall first, then remove everything that is related to the screensaver and then install again.
What do you mean by related to the screensaver?
I have uninstalled and reinstalled twice.
Mainly I mean this folder:
C:\Users\YOUR_USERNAME\AppData\Local\Endless Slideshow Screensaver
If this folder exists after you uninstall - delete it.
Don't have that folder but do have several with Endless Slideshow Screensaver after uninstall. Should I delete all of them?
Yes, sure!
