Could I download sequential files such as
www.xyz.com/files/zip/zipfile0001.zip
www.xyz.com/files/zip/zipfile0002.zip
www.xyz.com/files/zip/zipfile0003.zip
www.xyz.com/files/zip/zipfile0004.zip
Even if not listed in index.htm?
Thanks,
JR
Download sequential files
Re: Download sequential files
Yes, of course you can do that. You'll need to create a new download project using one of those URLs as a starting address, for example
http://www.xyz.com/files/zip/zipfile0001.zip
Then you must set the target files to
*.zip
After the project is created, open the project properties (menu command Project - Project properties...) and select the Starting addresses section. Here you must add the rest of your starting addresses to the project. In your case I'd suggest clicking the Import / Export URLs button to open the built-in URL generator which can easily generate a lot of sequential addresses in seconds and then add them to the project with a single mouse click.
*.zip
