can't find files from project
iamjoe
Post by iamjoe » 18 Jul 2012, 23:52
I created a project, I ran the project, I saw a list of files fly by as the job was running, but when I go to the target folder where the images should be, nothing is there?
Re: can't find files from project
Post by Maxim » 19 Jul 2012, 13:24
Maybe they were filtered out by "Image size" filter? Try removing all filters from project and re-running it.
iamjoe
Post by iamjoe » 19 Jul 2012, 18:32
There aren't any file/image restrictions
http://screencast.com/t/Wtpmtv8a
There is a number fo what I am guessing are images next to the project, however I am not finding them (even if I search for a file name)?
Post by Maxim » 19 Jul 2012, 22:00
OK, give me starting address and file types you want to save. I'll try help.
iamjoe
Post by iamjoe » 19 Jul 2012, 22:08
Thanks. I am looking to get the images from www.crestron.com (just the home page). I want to be able to have it working at my end.
Joe
iamjoe
Post by iamjoe » 19 Jul 2012, 22:17
I found the images. I'm working on a vm and finding them was tricky.
Post by Maxim » 19 Jul 2012, 22:23
Oh, OK...
