Find only big images with web picture search
Robb
Post by Robb » 03 Mar 2009, 13:40
I'm trying to find pictures with Extreme Picture Finder. How do I make the program to find and download only big pictures from search engines?
Regards,
Robb
Re: Find only big images with web picture search
Post by Maxim » 03 Mar 2009, 14:06
Dear Rob,
There are two ways to tell Extreme Picture Finder to limit image size. First you can limit image file size by setting minimum file size allowed for download. Second - you can limit image size (in pixels) by specifying minimum image width and height.
To do it you have to click [ Next > ] button several times when you create new Search in Extreme Picture Finder to rich the end of the New Search Wizard. On the last step you will see a box named "Show advanced search properties". You have to check this box and click [ Finish ] button. You will see the "Search properties" window.
Here you can select 'File size' section, check the "Do not download small images, less than" box and enter minimum image file size in the corresponding edit field. Also you can select 'Image size' section where you can specify minimum image width and height.
Please note, that if you're downloading thumbnails along with full-size images (in the following search modes "Only thumbnails", "Thumbnails and full-size images", "All images") then a thumbnail will be downloaded for all images (big and small). The limits above work only for full-size and related images.
