I copied it on a clipboard and pasted it into notepad++, but there are quite a few empty lines. We got 25000 files and we created that number of lines as well.
However, when you remove an empty line from notepad++, it appears to be less than 1000 lines. I think there is a log missing in the process of copying, is there a way to export the log to Excel or txt other than to export it to the clipboard?
Is there any way to export the project log to a file?
Re: Is there any way to export the project log to a file?
Yeah, currently it's not that obvious, but exporting a download log into a file is done using menu item [ Project - Export file list... ]. Adding the [ Export ] feature to the log viewer window is already in the to-do list.
