VK template is not working properly at the moment, I think the VK site has been updated, the album section now writes photos and downloads 1 image 10 times, can you update the template?
Now the photo link looks like this https://vk.com/photos34065597
When you download in this way, it only downloads 1 20 image, but most of the time it downloads 20 different sizes of the same image
VK template error
Re: VK template error
Yes, looks like they did change something. Thank you for reporting it. I'll try to fix it.
OK, it's done finally. I had to update the program for that, so you will need to install the most recent version of Extreme Picture Finder first:
Download Extreme Picture Finder
Then you will need the updated vk.com photo template:
vk.com photo album downloader
Then you will need to create a new project with a new template version (settings from new template versions are not applied to existing projects). Once the project is started - log in to your vk.com account in the built-in browser and when you see the album photos - scroll the photo list down a bit to make it load more photos at least once. After that, you can click the [ Continue download ] button to start the download process.
Please try it and let me know if it worked for you this time.
Thank you, it downloads all the images now, but it downloads at least 5 different sizes of the same image. When I say to download below a certain size from the settings, it skips the original images with small sizes. The template worked perfectly in the old version, but unfortunately in this version, it downloads at least 700 images from the page with 200 images. Before writing to you, I wanted to filter by size and filter by width and aspect ratio, but I noticed that most of the time it downloads incomplete images. I looked for a difference in the url addresses, unfortunately I couldn't find it either. I would be happy if you can help me in this regard.
1. What version of the program do you have?
2. Did you create a new project of used existing one?
3. Give me please exact album URL, which shows this behavior.
I'm sorry, the problem occurred because I entered the link as an album instead of photos, since the album still appears as a link on the template page. It works very well. Thank you for your interest and interest. 🙏🏻💐
